12.7 s60 engine head gasket in Larado?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Elroythekid, Apr 18, 2021.
  1. Elroythekid
    Elroythekid Road Train Member
    1,603
    1,501
    Sep 9, 2010
    Halifax Nova Scotia
    Stopped in San Antonio for a truck wash and they sprayed the engine off, as per normal. Noticed the temp gauge fluctuating after that on the way to Larado. Now looks like coolant has gone dark, oil looks ok?
    Any recommendations on who to take it to here, or try to limp it back to Canada?
    Every US dollar is 1.32 of my dollars.
    Trucking Jobs in 30 seconds
  3. 062
    062 Road Train Member
    4,504
    8,936
    Oct 20, 2013
  4. AModelCat
    94,245
    Sounds like it could be an oil cooler leaking if the coolant has gone dark due to oil contamination.
    Rideandrepair, DUNE-T and Elroythekid Thank this.
  5. John E.
    John E. Light Load Member
    59
    135
    Apr 4, 2021
    New Brunswick
    I had the same problem in Fargo a few yrs back. Got the company I was working for to pick up my flat bed load and deliver it. I then bobtailed it back to Canada, actually New Brunswick. I kept a constant watch on my Temperature and checked the oil often. Got in a big snow storm in Chicago, followed the storm all the way home. Rebuilt the engine, saved some extra big money and got back to work. Hope everything works out for you. Not a good feeling.
    Rideandrepair and Elroythekid Thank this.
  6. Elroythekid
    1,603
    1,501
    Sep 9, 2010
    Halifax Nova Scotia
    There is definetly some sludge in the tank, but the coolant still looks clean. I do t have a filter system and always carry test strips and tested it and it tested ok for PH. The gauge fluctuating concerns me. I'm going to top it up and head north after my reset. I told them no US loads, direct to Canada and a light one. I'll keep a watch on the ph and oil, change them if needed. I would like to get it pressure tested but not disturbing it seems better at this juncture. 20210418_154102.jpg 20210418_154102.jpg 20210418_154118.jpg
    Rideandrepair Thanks this.
  7. Old Man
    Old Man Road Train Member
    4,148
    10,972
    Apr 3, 2009
    Oklahoma City, OK
    How much and how fast does temp gauge change?
  8. Elroythekid
    1,603
    1,501
    Sep 9, 2010
    Halifax Nova Scotia
    It goes from just over 175 to almost 200 no load, temps were low. It's never done that, always rock solid.
  9. John E.
    59
    135
    Apr 4, 2021
    New Brunswick
    Actually, it looks not bad, the prestone that is. I think you will be fine to get back.
  10. Old Man
    4,148
    10,972
    Apr 3, 2009
    Oklahoma City, OK
    Check wires at sending unit, truck wash may have affected them.
    when I had a bad head gasket temp would rise fast from exhaust getting in water but cool down real fast when not pushing hard, could hear a noise in motor.
  11. 4noReason
    4noReason Road Train Member
    2,249
    646
    Nov 29, 2012
    oh my truck tank looks like this . it flucuates too. same engine. never thought it was a oil cooler. gonna have to get it looked at
  • Draft saved Draft deleted
