That's what it's doing, when I get into it it jumps up pretty quick. Never use to move that fast before? Dipped the coolant again when I got to the ts with white paper and its clean as a whistle. Tested ph again, it's ok?
12.7 s60 engine head gasket in Larado?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Elroythekid, Apr 18, 2021.
Page 2 of 7
I skimmed over this. Take the CAC out and wash the rad, wash the CAC. They are known to collect junk in between them. Had 10 new in a fleet.Rideandrepair, John E. and Elroythekid Thank this. -
But sure you don’t have a bad sending unit? Or connection to sensor. What does a FLIR temp gun say?. If can get one compare the temps to what sensor shows. just maybe some ideas to ponderRideandrepair, John E. and Elroythekid Thank this. -
Rideandrepair Thanks this.
OK is it oil or fuel in the surge tank? Looks like fuel to me. Oil usually turns the whole tank black. Fuel darkens the coolant appearance.
Rideandrepair, Elroythekid and John E. Thank this. -
Did I miss something, he said coolant was clean on a white paper towel?
Rideandrepair Thanks this. -
Rideandrepair and jamespmack Thank this.
So what else make you think you have a head gasket problem? Just the temp fluctuations?Rideandrepair Thanks this. -
Page 2 of 7
