12 volt outlet outage
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by jhens111, Sep 15, 2014.
  1. jhens111
    jhens111 Bobtail Member
    19
    Dec 31, 2013
    I have a 2013 Peterbilt that the 12 volt cigarette lighter Outlet went out on this weekend ...have checked all the fuses Behind thel glove compartment all good any other ideasthanks for your help
  3. xsetra
    xsetra Road Train Member
    5,109
    6,972
    Aug 21, 2011
    Check your connections behind outlet.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Sometimes the outlet is fused in the outlet assembly itself. If you have a meter you can see if you are getting the 12vdc at the wire connections (unplug them from the outlet). If so, then the outlet is bad. If no 12vdc then the problem is elsewhere.
  5. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Some times the "Cigarette Lighter" outlet is not deep enough to give SOME devices (for me, GPS and XM Receiver) the proper positive and ground connections. Usually the ground on the side of what's being plugged in. Try a cell phone charger or something with a shallow shaft, and see if you got power to those.
  6. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Normally if you look you can get the splitters with the shorter connector for the DC, but the outlets on the splitter are deep. You have to look around though. If the plug keeps slipping out of the DC connector you can take a cable tie and slide a couple of pieces between the plug and connector. This will usually hold it in tighter.
  7. jhens111
    19
    Dec 31, 2013
    No plug works...no power at all
  8. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Did you take the connectors off the back of the plug and see if you have 12vdc on the wire connectors?
  9. X-Country
    X-Country Medium Load Member
    645
    462
    Mar 27, 2014
    check the fuse box on the driver side of the truck below the bunk (lift the bunk up) in the sleeper, there is a fuse box down there that will have fuses to the power outlets.
