13/18 speed transmissions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Brandonpdx, Mar 9, 2020.
  1. Brandonpdx
    Brandonpdx Road Train Member
    4,100
    3,860
    Dec 27, 2007
    Elkhart, IN
    Just a quick question about any transmission with a splitter valve on the side...is it bad on these to downshift with the splitter valve by just letting off the throttle and letting it do it's thing? Or should you pull it out of gear and blip the throttle like you would a normal whole gear downshift?
  3. AModelCat
    145,339
    I never pull the main box out of gear when splitting up or down unless I'm actually shifting the main box up or down a gear (eg 5H to 6L or 6L down to 5H). On the downshift I just give it a little fuel so it syncs up and goes in.
    Bean Jr., mile marker 27 and 650cat425 Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    It is called pre-selecting the gear. Perfectly fine to do with those transmissions. Even with the range shift. No need to wait, just let it do it's thing.
    Bean Jr. and mile marker 27 Thank this.
  5. 650cat425
    650cat425 Road Train Member
    1,548
    11,042
    Jan 26, 2020
    Pennsyltucky
    ^^^what he said.
    Bean Jr. Thanks this.
  6. HoneyBadger67
    2,056
    4,509
    Dec 15, 2018
    Savannah, TN
    I thought preselecting was moving the splitter before you took it out of gear, then (optimally) the back box splits while you're completing your shift. I've stopped this practice and my shifts in the 13 have become smoother.
    Diesel Dave Thanks this.
  7. Diesel Dave
    7,302
    14,639
    Jan 20, 2010
    Hesperia, Ca.
    On a 13, in high range, I go from hi on the splitter, grab the whole next gear and then split down to low. When I split to high, I just barely press on the clutch so the synchro go in smooth without the slapping. I have always shifted any 13 speed this way. My transmission guy confirmed it was the correct way.
    650cat425, Bean Jr. and HoneyBadger67 Thank this.
  8. fast1buzz
    fast1buzz Light Load Member
    93
    115
    Feb 6, 2019
    colorado
    This is the correct way to shift a 13 spd particularly the earlier models. I you shift them any other way you will destroy the back box eventually
    Brettj3876, Diesel Dave and 650cat425 Thank this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,879
    May 31, 2010
    West Harrison, In
    RTO and RTLO split differently. Need to know your model.
    ChevyCam, SAR, swaan and 2 others Thank this.
  10. swaan
    swaan Road Train Member
    2,943
    4,371
    Jul 12, 2009
    BC canada
    You preselect on a rtlo .
    You don't on a RTO.
    dirthaller, SAR and spsauerland Thank this.
  11. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    yup, get in a rto for the first time after years of rtlo and you will feel like an idiot.. BTDT
    swaan Thanks this.
