13 speed still grinding
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 260REM, May 28, 2026.
  1. 260REM
    260REM Bobtail Member
    21
    12
    Aug 9, 2023
    I am having a problem with transmission grinding on the high to low range selection. Its an RTO 14613 and I just had the back box rebuilt and it grinds slightly less but still grinds. It doesn't grind every time, kind of intermittent. What is my next move? Am I driving it wrong? All I know is I don't know. Thanks with any help.
  3. okiedokie
    okiedokie Road Train Member
    14,976
    122,303
    Jun 13, 2011
    PNWET
    From my miniscule experience, extended range preselection is what causes that issue.
  4. 260REM
    21
    12
    Aug 9, 2023
    Do you mean say I'm flipping the range lever down way before i actually make the gear change?
    What I try to do is get mph down to about 15 or a little less before I make the change and I think I'm flipping lever and pulling shifter pretty soon after. I will pay better attention next time I run it.
  5. bad-luck
    bad-luck Road Train Member
    3,520
    6,531
    Nov 16, 2013
    Baltimore, Maryland
    If your transmission grinds when going from low range to high range, the synchronizer is bad.
  6. 260REM
    21
    12
    Aug 9, 2023
    That's what i thought too, so i had it replaced. Still grinding though. It is working fine on the up shift, just misbehaving on the occasional down shift.
  7. bad-luck
    3,520
    6,531
    Nov 16, 2013
    Baltimore, Maryland
    Is it grinding when you are splitting gears down shifting, or when you are down shifting from high range to low range?
    Trucker61016 Thanks this.
  8. 260REM
    21
    12
    Aug 9, 2023
    from high range to low range only, so far
  9. bad-luck
    3,520
    6,531
    Nov 16, 2013
    Baltimore, Maryland
    Still sounds like the synchronizer.
    @Heavyd @Goodysnap may have more insight
    Stringb8n Thanks this.
  10. Judge
    94,898
    Can also change the splitter itself.
    Had an international 9900 do that, it’d grind every time you went high to low.
    Splitter/slave valve
  11. Stringb8n
    Stringb8n Road Train Member
    1,720
    2,282
    Sep 27, 2015
    Not to bust your balls, but you mean, "I think I got the synchronizer changed". You may have paid for it to be replaced, but what you actually got could be a totally different story. For all anybody knows, some "mechanic" put saw dust in there to help make it quiet.
