o4 14 liter started burning oil gal every 800mile has no egr has 171702 b/w oil smells burnt changed oil ran 5000 miles with no oil loss then it started to burn it again at the same rate no oil in turbo not very much blowbye but blowbye smells burnt
14 liter detroit burning oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by little cat 500, Jul 4, 2014.
not 100% sure on miles was told it had 250 on a inframe but spedo says 950 trucks had alot of injector problems
stuck/worn rings or burnt liners. and with the injector problems could have washed a liner or 2 out with fuel. sounds like it needs an inframe, or at the least liners and rings but I would inframe it.
ok oil was full of fuel i was hoping not to inframe it just yet i changed the oil see what happens
You know what's going to happen.
boom lol if i change oil it will run 4 or 5 thous then start all over trying to buy alittle time
did have a bad injector but i think the damage may be done still burning oil at the same rate about gal every 800 mile motor dont smoke very little blowbye
