14 Maxxforce dt soot issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Duramax007, Jul 22, 2024.
  1. Duramax007
    Duramax007 Bobtail Member
    Hi all, I have a 2014 international 4300 with the maxxforce DT engine that keeps building soot and causing random low power.
    The engine on this truck was replaced in 2019 with a new engine. I would guess it has around 50k miles maybe a little more on the engine. About a year ago the EGR crossover seal on the intake side blew out. We replaced the seal and it blew out again shortly after. The then clamped the pipe (doesn't appear to be deformed) and it hasn't had an issue until now. The driver says when this happens he takes a rubber mallet and hits the cat and dog and it starts to have power again. The only code is the code for tc1 top. When we pulled the pipe off last year the cooler looked not plugged. Any ideas?
  3. Duramax007
    Just a note. When the issues started again I noticed the seal had slightly pushed back out and I tapped it back in.
  4. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    You need someone who knows these engines well. If I was working on it, I would review the codes, record a 0-60 performance snap shot, run and record an air management test, then record a regen and evaluate the data and troubleshoot from there.
  5. Duramax007
    Ok I will do that tomorrow. Problem here is unfortunately even the dealers don't know much in my area. I was fortunate enough to be able to talk to a service manager out in California and they gave me some good information as well. I'm hoping someone else has had a similar issue that could shed some insight
  6. Inderjit
    Inderjit Heavy Load Member
    716
    704
    Sep 17, 2017
    Does it have DEF? International tried to get away from using the DEF
    system by using large amounts of EGR. It did not work out well!
    I suspect your intake ports are getting plugged with carbon.
    Can you post the last eight of the VIN or PM it to me.
