15 speed direct drive with 2.85 rears slow up hills and poor mileage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by javelinjeff, Jun 21, 2015.
  1. rank
    rank Road Train Member
    9,918
    113,503
    Feb 11, 2010
    What do you call a hill? Figure out what your final drive is in 6th.
    You can always sell the rears to Richter.
    Cetane+ and MJ1657 Thank this.
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    What's your Torque spec on it?
    I agree with putting it on a dump and checking the power output. A pittsburg power box might do wonders for this truck.
  4. javelinjeff
    javelinjeff Medium Load Member
    621
    185
    Aug 30, 2007
    victorville,ca
    24-26 psi
  5. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    talked to them the other day,,they say the Low NOX reflash kills the power of these motors
  6. granhawler
    granhawler Light Load Member
    296
    56
    Feb 26, 2011
    A 15 where you split the top end?? Every 15 I've ever seen has the deep reduction gears & either an overdrive or direct.
    Cetane+ Thanks this.
  7. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    If you split the top end its not a 15 it's a 13spd.
    Cetane+ and granhawler Thank this.
  8. granhawler
    296
    56
    Feb 26, 2011
    Exactly, I don't mean to be rude & don't claim to know everything about trucks. But, some of the questions people ask on here make me shake my head. Its a wonder most of them can tie there shoes let alone move a truck down the road.
  9. 062
    062 Road Train Member
    6,203
    33,417
    Oct 20, 2013
    24-26psi is a bit low for a single turbo,way low if it's a acert. Have you checked the air to air for leaks? Last cat I ran was a mbn,it was in the 32-34psi range.
  10. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I'm not ruling out motor issues. With that said that trans is not set-up to drive those rears. A 15spd is a glorified 10spd. Great trans durability wise and nothing wrong with 15. But to drive 2.85 rears loaded heavy with any kinda conviction you need to be able to split gears on a pull. Otherwise you'll be doing a lot of straight sticking. In my opinon the 15 is holding the truck back. Had a bunch of 15s over the years and on everyone that I changed to a 13 the trucks got better mpg, better top end, better pulling power on highway. Off-road the 15 has deep reduction for better low end hands down.
    granhawler Thanks this.
  11. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    My friend just did that and you are 100% right on the money, a whole different truck with the 13.
