16 5700 xe, rear ac blowing warm
Discussion in 'Western Star Forum' started by scokat, Jul 6, 2019.
  1. scokat
    scokat Bobtail Member
    33
    20
    Oct 14, 2013
    2016 rear ac blowing warm air, put gauges on high and low side, proper pressures, front ac goes down to 66, but rear ac still blows warm. took drawers out and watched the actuator move from side to side when switching from heat to ac. Any suggestions on where to start?
  2. Cetane+
    Cetane+ Road Train Member
    1,296
    872
    Sep 29, 2013
    Albany, NY
    Do the lines feel cold that go to the rear blower? Are the heater lines still hot? Do you need to turn the heater line valves off?
  3. scokat
    33
    20
    Oct 14, 2013
    lines are ice cold, do i need to cut off the heater lines?
  4. Cetane+
    1,296
    872
    Sep 29, 2013
    Albany, NY
    If you turn off the heater lines and it blows cold it might tell you that the valve to turn off the hot water to the heater core is not working right. Or you just need to turn off the heater lines to get maximum cold.
  5. scokat
    33
    20
    Oct 14, 2013
    I looked but could not see the shutoff valves, anyone have info for a 5700, probably in front of my eyes but i cant see them.
  6. ShortCircuit
    ShortCircuit Bobtail Member
    26
    14
    May 7, 2017
    I don’t believe bunk has heater shutoff valve on 5700. Heater is always on only air selection flap controls which side cabin air is pulled from. I ended up installing a brass ball valve on the hose that supplies coolant to the bunk heater in the engine compartment. There are two hoses above EGR that connect to metal pipes and run parallel with the R134 refrigerant loop under the cab that deliver and return coolant. You can just split the hose and install inline valve. In the summer just open the hood and cut off coolant circulation.
  7. stibtown
    stibtown Bobtail Member
    8
    7
    Jul 28, 2013
    Blairstown,Ia
    Do you need to install a valve in the return line or just in the supply?
  8. RocketyMan
    RocketyMan Medium Load Member
    308
    137
    Jun 5, 2015
    Last 6 of vin...?
  • Draft saved Draft deleted
