I just paid $26,000 for an out-of-frame that lasted 17,000 miles! Now the mechanic is not standing by his work and says it was caused by an over-rev. However, I have a histogram on the truck that says the engine has never been over the 2120 rpms that the truck is rated for. I will most likely end up in court over this, anyone ever been through a similar incident? Any advice?
17,000 mile out-of-frame
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nighthawk1925, Oct 20, 2020.
Engine make/model/serial #. Was it a dealer or independent shop? Was it a parts flaw or workmanship issue? How much time between rebuild and failure (in terms of weeks/months)? What was the scope of the rebuild (what was all replaced)? What part was the root cause of failure?
There are a suprising number of mechanics on the forum. The more info you can give, the better the answer we can give.spsauerland, Rideandrepair, Dino soar and 2 others Thank this. -
2120 is considered over rev.
You gotta watch them R's going down hill. And be careful with the jakes.
Most of us don't go much over 1700. Maybe 1800 if your climbing hills.
Used to be a time if you hit the Jake's at 1800. You sucked the valves in.Last edited: Oct 20, 2020
Dave_in_AZ, Rideandrepair and 650cat425 Thank this. -
How do you suck a valve in using the jakes? Never heard of that before.
Opendeckin, Brettj3876, swaan and 10 others Thank this. -
Back in the day Jakes always worked best at 2100 per Cummins and Detroit. Cat always said to run the brakesaver at 2100. Never no problems. Above that around 2400 maybe.
Opendeckin, God prefers Diesels, p608 and 4 others Thank this. -
for $26k. i would have went to a known engine shop. it would have came with a warranty
My Detroit turns 2350 just fine. On fuel or on Jakes.
More info needs to be provided.Brettj3876, Dave_in_AZ, MM71 and 3 others Thank this. -
Cat had many 2300 RPM files for C-15/C15 and other truck engines.
Opendeckin, Brettj3876, Dave_in_AZ and 4 others Thank this. -
I want to hear more about this...
My little baby Cat 3126B would run 2400 all day long everyday moving 33,000 gross down the road and get almost 500,000 between overhauls. I know apples and oranges right? Lol!
MM71 Thanks this.
