1980 mack fuel issue
Discussion in 'Mack Forum' started by Cjkcustoms, Mar 8, 2022.
  1. Cjkcustoms
    Cjkcustoms Bobtail Member
    7
    Hi guys I have a 1980 mack I'm trying to get running correctly. It starts and runs but when it idles for about 5 min it stumbles and stalls out. When this happens It cranks long and finally starts. I thought it was sucking air so I replaced all the fuel lines as I thought it was sucking air. The fuel filters are new and have been filled I've primed all the way to the injection pump and this still happens. I'm a mechanic but not a diesel mechanic. I understand how the engines work but when It comes to drivability issues I'm laxed. I'd like to exhaust all possibilities before I shoot the lock off the wallet for an injection pump
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,411
    7,974
    Jul 11, 2012
    in the bush somewhere
    When it dies, did you spin the fuel filter off to see if it has fuel at the filter?
  4. Cjkcustoms
    7
    Yes primary filter is full secondary filter is a little low
  5. Cjkcustoms
    7
    062 Road Train Member
    6,385
    34,163
    Oct 20, 2013
    @Brettj3876 may have some ideas.
    It’s a long shot, but take the fuel caps off and see if that helps. Vents may be clogged.
    Brettj3876 and Cjkcustoms Thank this.
  7. Cjkcustoms
    7
    It does it if the cap is on or off
  8. Cjkcustoms
    7
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,062
    Nov 18, 2014
    Land of local
    I was gonna say check the pickup in the tank to make sure it's not clogged. Sounds like it might possibly be the issue. Runs for a bit then whatever is down there gets sucked back up and stalls it
    062 Thanks this.
  10. Cjkcustoms
    7
    This gives any other ideas the pick up pump is after the primary filter and before the secondary. And it is a mechanical pump
  11. Brettj3876
    11,257
    54,062
    Nov 18, 2014
    Land of local
    At least there's no electronics to worry about Lol
