1989 F800 with Allison transmission; Chelsea 220 PTO won't engage
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kmmontandon, Jul 11, 2026.
  1. kmmontandon
    kmmontandon Bobtail Member
    14
    May 21, 2021
    The truck itself serves as a fuel truck, which is where the problem started:
    After fueling a plane, I disengaged (it's a Chelsea locking air switch) the PTO, heard the driveshaft stop turning ... but the light didn't go out, and the truck wouldn't go into gear. After a few failed re-tries to disengage, the ramp crew had to push me out of the way. I turned the truck off then restarted, and the light stayed off and the truck would go into gear. That's the pattern now - I go through the procedure to engage the PTO, the light comes on, but nothing physical actually happens. The PTO doesn't start turning, but I can't put the truck into gear - the PTO's engaged as far as the interlocks are concerned, and after toggling it off the light stays on and it won't go into gear unless I restart the truck. Which suggests electrical rather than mechanical?
    After checking a few other things, I pulled the solenoid off the PTO, and everything looks sound, but I have no expertise at this. The fork moves by hand, but that doesn't mean it moves by air of course. And the middle input gear looks like it sticks in too far for the output gear to mesh with. I have no documentation/diagrams/manuals to work from to see if everything's aligned right, so I've included a bunch of pictures for hopefully far more expert eyes to see and tell me if anything jumps out.
    EDIT: I marked the input gear with a grease pen then drove the truck a few dozen feet. The gear didn't move.
    IMG_7923.JPEG IMG_7928.JPEG IMG_7929.JPEG IMG_7930.JPEG IMG_7931.JPEG IMG_7932.JPEG
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,589
    6,683
    Aug 26, 2014
    Problem with the air shift unit? Could the shaft be slipping in the fork? I think the gears look fine.
    Oxbow Thanks this.
  4. Star Rider
    Star Rider Road Train Member
    1,861
    20,852
    Sep 23, 2019
    Make sure where the air exhausts from the switch isn't plugged up. It may be exhausting enough to disengage the PTO but holding just enough in to activate the switches for the lockout.
    Oxbow and BoxCarKidd Thank this.
  5. Star Rider
    1,861
    20,852
    Sep 23, 2019
    If you see any of these in the switches or valves for your PTO remove them and try it. I have seen these 'mufflers' cause problems with lift axles and fan clutches by not exhausting completely.
    BoxCarKidd, Oxbow and JB7 Thank this.
  6. kmmontandon
    14
    May 21, 2021
    While I had the solenoid pulled, I marked the input gear with grease and ran the engine and even drove a loop... and the gear didn't move. I'm wondering if the dedicated PTO gear on the transmission itself is disengaged somehow, but I thought it was supposed to be full-time no matter what, as is the input gear on the PTO as a result. So even if the fork is shifting over properly, there's nothing moving to engage with.
    Except that still wouldn't explain why turning the truck off and then restarting completely resets everything ... there's got to be an electrical malfunction, and I don't have the information on the AT-545 I need to know what sensors it has.
  7. Raffito
    Raffito Light Load Member
    90
    57
    Aug 25, 2019
    Ingram, TX
    The fork and shaft has a spring that returns the fork in off(disengage) position when you turn the PTO off and air pressure is release through the filter/exhaust port. It could be that the spring is weak not returning the fork and gear when under load (engine running) . When you turn the truck off you take the load off the shifting gear and it goes back in the disengaged position. The fork should not be easy to move by hand.
    BoxCarKidd and JB7 Thank this.
