1991 379 electrical issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Coolbreezin, Oct 22, 2020.
  1. Coolbreezin
    Coolbreezin Light Load Member
    228
    163
    Jun 11, 2016
    Florida
    Hey all. My idiot lights no longer illuminate, my electric gauges no longer work and my jakebrake doesnt work. However, sometimes everything will operate correctly for about 5 miles. Ultimately my engine fan switch governs it all. I thought maybe a wire issue but bouncing has no effect. I changed the switch and no better. Sometimes it'll all start working while I sit and idle. I reached in my dash and jiggled wires around by the handfull, nothing. Since it works sporadically, it's not a fuse. Im not an electrical person. Any advice?
    Trucking Jobs in 30 seconds
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    3,416
    4,717
    Aug 26, 2014
    A little different deal but similar with the manual fan switch light coming on with a Pete. Make sure all the battery cable connections are clean and tight.
    Your deal sounds different but that is easy to check. The truck I worked on would shut down while driving and it had one loose battery connection. Truck had under 100,000 miles.
  4. Goodysnap
    Goodysnap Road Train Member
    2,300
    5,193
    Jul 12, 2017
    Your going way back on me.
    Check the 150 amp breaker driver side of the dash top. See if you have good power to both sides when its broken.
    pushbroom Thanks this.
  5. Coolbreezin
    228
    163
    Jun 11, 2016
    Florida
    If the fuse yr speaking of is popped, the dash wouldnt come to life at all. It works sporadically for a few miles.
  6. Coolbreezin
    228
    163
    Jun 11, 2016
    Florida
    UPDATE: after digging through the dash for a while I climbed out of the truck and noticed the fuse box had a tripped breaker I pushed it back in and also found that the "dash panel" fuse was popped. Fixed those two and dash works fine. But now it raises the question why did the dash work sporadically?
    Like "how many licks does it take to get the the center of a Tootsie pop" kinda question. Guess the world will never know.
  • Draft saved Draft deleted
