1992 international 4900 electrical gremlins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Grimjack33, Aug 4, 2026.
  1. Grimjack33
    Grimjack33 Bobtail Member
    Hey everyone and thanks in advance. I bought 92' 4900 with a dt466 for personal use and my electrical problems are about to cause me a stroke.
    This is first actual TRUCK and I'm on the low side of the learning curve. I'm not really mechanically inclined for sure. I've changed all the fluids and filters and the truck runs great! ($100 for an air filter ####!) My.problem is electrical. I wish I was making this up but when I got it I had 2 tail lights and one brake light. Changed the fuel filters and had all rear lights. Changed the oil filters now I have nothing in the rear. Headlights.are fine and so are backup lights.
    Cleaned the battery disconnect it was a mess and will clean the battery to frame connection tomorrow. How many more ground locations are there? I understand there is a ground some where in the back for the lights at least but I don't know where. Also, gauges at one point they were all good. Now it takes 5 to 10 minutes to get my fuel and voltmeter to come to life. Thank you again.
  3. Gilbyson
    Gilbyson Light Load Member
    50
    62
    Apr 26, 2012
    Wyoming
    My 86 was having a self-resetting circuit breaker acting funny. I replaced it with a regular fuse. The breaker is on the fuse panel. It was getting very hot and that's how I found it was the problem. I dont know if a 92 will have the same breakers though.
  4. 201
    201 Road Train Member
    13,011
    26,856
    Apr 16, 2014
    high plains colorado
    Welcome, and welcome to the world of older trucks. I don't think the filters have anything to do with it, sounds like a ground problem. Very common on older trucks. Make sure the cab has a ground wire, run a new one just in case, and battery to frame is also a big problem. $100 air filter is the tip of the iceberg, my friend.:thumbup: Best of luck.
    jaffles Thanks this.
  5. jaffles
    jaffles Medium Load Member
    561
    1,381
    Oct 18, 2017
    Australia
    My 10c is turn lights on, then make you way around the corners of the truck wriggling wires, tapping lights etc. If thigs go out, or come on, than you have found at least one point where you will have a rubbed-exposed wire earthing, or a loose connection. Rectify and carry on.
    Trucker61016 and 201 Thank this.
