1994 3406E Turbo Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by McMahons Trucking, Aug 12, 2018.
  1. McMahons Trucking
    McMahons Trucking Light Load Member
    135
    49
    Jul 4, 2018
    I had the pleasure of replacing a thermostat this weekend and when I had the intake side of the breather off I noticed my turbo wheel was all chewed up. Can I get just this part and replace it while the turbo is still installed on the engine or do I need to replace the entire turbo?
  2. swaan
    swaan Road Train Member
    2,182
    2,383
    Jul 12, 2009
    BC canada
    Those things spin upwards of 100,000 rpm and balanced as an assembly.
    You need a new turbo . Find out why it's all chewed up also. Dont want the new turbo to suffer the same demise.
    SAR, Oxbow and AModelCat Thank this.
  3. Cam Roberts
    Cam Roberts Heavy Load Member
    970
    988
    May 13, 2018
    yeah turbo is not that expensive and you can install it. its very easy. probably got chewed up from previous owner had something go into it. No need to be alarmed. just replace the whole turbo asap. Somewone will chime in soon with a replacement part number for you.
    Oxbow Thanks this.
  4. McMahons Trucking
    135
    49
    Jul 4, 2018
    I found one on Amazon for 605 from JM Turbo Technologies. Any experience with them? This one looks like they were chipping wood with it.
  5. swaan
    2,182
    2,383
    Jul 12, 2009
    BC canada
    That will be a Chinese knock off.
    Get a genuine borg warner or cat.
    John A., SAR, Oxbow and 1 other person Thank this.
  6. McMahons Trucking
    135
    49
    Jul 4, 2018
    That's what i figured it would be. Oh well. Guess ill have to shell out some bucks.
  7. MM71
    MM71 Medium Load Member
    439
    319
    Jun 28, 2008
    AZ
    Good time to do some research on here and find you a way to make some more boost!
  8. gospelfortheroad
    gospelfortheroad Bobtail Member
    8
    Jul 31, 2018
    We put a cheep remanufactured Turbo on a diesel motor out on the farm and one of the blades flew off of that Turbo and it's stuck on one of the Pistons and after that blade got hot on that aluminum piston it blew a hole in it, so we had to take the motor apart and replace that sleeve and piston. I'm not saying that would happen to you but I wouldn't try to get by Cheap when you put a turbo on.
  9. McMahons Trucking
    135
    49
    Jul 4, 2018
    I don't need that hassle or expense right now.
  10. DieselTech_Aus
    DieselTech_Aus Light Load Member
    213
    215
    Dec 20, 2017
    WA
    fit a borg warner 0000 turbo with billet compressor wheel.
    cheaper and FAR better than cat reman.
    just ensure you check the CAC system and the ENTIRE air intake system for debris that may damage the new turbo.
  • Draft saved Draft deleted
