1996 3406E cutting out.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by walton379, Aug 24, 2010.
  1. walton379
    walton379 Light Load Member
    63
    Nov 21, 2008
    Moon Lake, MS
    Hey guys it's been a while. I've searched and can't seem to find what I want. The best way I can describe what's going on is this. I have a 96 w900l 550 3406e. When accelerating sometimes it Justs cutts out. The engine does not quit it just looses power then right back on. I'm almost positive it's an electrical issue. My first guess is the accelerator pedal. Any ideas?
  3. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    It could be a couple of different things causing this, timing sensor, throttle position sensor, speed sensor. You need to hook it up to a laptop and see what faults are stored in the ECM, before you start changing parts
  4. p-wee
    p-wee Bobtail Member
    23
    Jul 4, 2010
    springdale,WA
    Dead spot????? Thats kinda what ur discribing....sound like throttle sensor.Mine 3406e did the samething.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    The first thing you want to do is clean the power and grounds, be sure to clean the grounds at the cylinder head stud, also check the connections at the battery's and the fuse holders.
    If you have the unit on the laptop and t does not have any codes, scroll down to the keys on total and watch the totals. If when it is running and it stumbles and the tally goes up it could be the power to the ECM or the ignition switch, or it's wiring.
    Just a thought!
  6. walton379
    63
    Nov 21, 2008
    Moon Lake, MS
    Thanks guys. Yes dead spot is it. While pushing down the pedal it looses power then if i move the pedal honor down slightly it comes back
  7. p-wee
    23
    Jul 4, 2010
    springdale,WA
    Yup!! thats what mine did.its just a part that wares out over a few hundred thousand. good luck!!!
  8. dbrat62
    dbrat62 Bobtail Member
  9. dbrat62
    Did you come up with the problem I have a similar one
  10. Diesel Dave
    9,587
    32,098
    Jan 20, 2010
    Hesperia, Ca.
    Way to revive an old thread. I had this similar issue and ended up being the harness of the injectors. The mechanic couldn’t fine the problem in the beginning, then he starting tapping on the harness connections and it sputtered. He had found the problem. Had the harness replaced, problem solved. At least for my issue on my former 3406E.
    HillbillyDeluxeTruck Thanks this.
