1996 DT466E IPR valve wiring problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Wreckerwrench96, Jan 17, 2020.
  1. Wreckerwrench96
    Wreckerwrench96 Bobtail Member
    I have a 1996 international 4700 LP a DT466 having problem trying to get the truck started acting like an IPR valve problem so I replace the IPR valve and I'm noticing that the wires how are the IPR valve are both hot meaning they're both positive I'm looking for some kind of help on this I'm not sure if it's supposed to be two hots or if it supposed to be hot in the negative so I trace the wires and I don't see any false as far as I can see please help
    Trucking Jobs in 30 seconds
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    2,935
    3,783
    Aug 26, 2014
    You Tube Hoglund Buss IPR, DT problems and similar stuff. They have some pretty good information. It will take you some time to get through it. Maybe then you can fix it? If not you will have a lot better understanding of what questions to ask here. Some people on here know a lot about them.
  4. ClineER
    ClineER Light Load Member
    208
    119
    Apr 27, 2016
    N.E. Oklahoma
    12v to ipr and second wire computer controls resistance to control ipr. If plugged in will show voltage but unplugged should show 0v on one terminal. To test ipr you can ground out that wire while running to send pump to full stroke for max oil pressure test.
  • Draft saved Draft deleted
