1998 w900 n14 cummins. Broken part found in oil pan
Discussion in 'Kenworth Forum' started by irishluck09, Jan 15, 2026.
  1. irishluck09
    irishluck09 Light Load Member
    281
    145
    Nov 24, 2019
    I'm doing an overhaul right now due to the #6 cylinder failing (rear one). Which looked like the rings or something failed. Had oil coming through the piston.
    So tore everything down. Dropped the oil pan and found a chunk of metal in the pan. It's about 1x1 inch. Nothing else in the pan except that. Picture is attached. Would anyone know what it's from? I can't figure it out
    Also, I've attached pictures of #6 piston. Definitely looks like something got jammed up between the cylinder and piston. Scrapped and melted it a bit and there is a ding in the side of it.
