1999 fld 120 cruise control not working?
Discussion in 'Freightliner Forum' started by 1985mudflap, Oct 5, 2021.
  1. 1985mudflap
    1985mudflap Bobtail Member
    20
    5
    Aug 30, 2021
    I can't get the cruise to working going down the road. I can idle the truck when the parking bakes are set. I have Jake's they cut out when the clutch is in gaged so I'm guessing it's not the clutch switch. I don't have a switch on my brake pedal. My speedo and tach also work. So I thought I would try the air switch, but I do not know which air switch is for the cruise control. I've found the air manifold behind the steer column just don't know which to change.
  3. Old Man
    Old Man Road Train Member
    4,436
    12,471
    Apr 3, 2009
    Oklahoma City, OK
  4. 1985mudflap
    20
    5
    Aug 30, 2021
  5. Old Man
    4,436
    12,471
    Apr 3, 2009
    Oklahoma City, OK
    Could be plug into ecm. The big one facing the fire wall, remove, clean and make sure it is in tight.
    1985mudflap Thanks this.
  6. 1985mudflap
    20
    5
    Aug 30, 2021
    Thanks I'll look into that. Would you happen to have any info on air switches?
  7. Old Man
    4,436
    12,471
    Apr 3, 2009
    Oklahoma City, OK
  8. Rideandrepair
    13,853
    46,141
    Aug 8, 2015
    I had same problem, till I found a second speed sensor on trans tail shaft. One on top, controls cruise. Bottom one controls speedo. Changed top one. Fixed. I don’t know if any air switches for cruise. One low air switch, and one brake light switch, usually plumbed in near parking brake, on FLD. Some Centuries and ? have them near steering column on right side.
  9. 1985mudflap
    20
    5
    Aug 30, 2021
    I have one speed sensor on top of the transmission it have two plugs one for the road speed and I thought the other was for the cruise but I'll double check it. Thanks.
    Rideandrepair Thanks this.
  • Draft saved Draft deleted
