2 questions for my oilfield folks
Discussion in 'Oilfield Trucking Forum' started by oilfieldfamily, Jan 17, 2026.
  1. oilfieldfamily
    oilfieldfamily Bobtail Member
    13
    Jun 15, 2025
    Guys
    1. What oil do you recommend to use on Vacuum pump? I have Challenger 607 pumps.
    2. How often do you have to add oil? I understand it depends on how many hours you work them also
    3. What brand you recommend for my steering tires? something good for this rough ### oilfield roads that doesn't cost arm and leg!
    THANK YOU!
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    996
    2,050
    Dec 15, 2021
    Liberty only uses Cooper Work Series (all position) in Louisiana from what the tire shop in Shreveport told me.I bought 8 for my trailer,will try them on the steers when I change those.
    77fib77 and oilfieldfamily Thank this.
  4. oilfieldfamily
    13
    Jun 15, 2025
    Thank you. I was asking about the steering tires for the truck itself.
  5. Arctic_fox
    4,464
    25,094
    Sep 16, 2016
    When i did oilfield.
    1. Its been almost a decade since i did oil but iirc we always ram cat SAE30, hell i run cat SAE30 in my PTO. Mostly because there are cats bloody everywhere so its easy to get more if something goes sideways.
    2. Mine never needed more. Though the company also pulled samples every 500 hours and changed as needed.
    3. Michlin. Im a rock bucket so i see even worse roads then oilfield roads, scrap metal and worse. The only thing that held up well in the oilfield were michlins and occasionally bridgestones and they also are the only ones that hold up on MY truck. Steers are the one tire thats hard to cheap out on and expect to last worth a ####. And if something goes wrong well.....fenders and hoods are pretty expensive.
  6. RockinChair
    RockinChair Road Train Member
    5,311
    13,980
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Bridgestone (R268, if memory serves) is what my old employer ran on the steer axle. And when I ran a vac truck we always topped off the pump oil reservoir after each shift, that way the next driver wouldn't run out. I think we refilled the flush fluid reservoir about once a week.
    oilfieldfamily Thanks this.
  7. oilfieldfamily
    13
    Jun 15, 2025
    Thank you for taking the time. Arctic_fox & RockinChair.
    RockinChair Thanks this.
  8. brelin388
    brelin388 Bobtail Member
    13
    16
    Oct 15, 2025
    For the pump, I run straight 30W in my 607 and just top off every couple of weeks depending on hours. Steering tires? Firestone’s been solid for me on rough roads without breaking the bank.
