2 Stroke Oil in Diesel Fuel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 217flatbedr, Jan 22, 2013.
  1. 217flatbedr
    217flatbedr Light Load Member
    99
    55
    Jan 20, 2012
    I noticed a guy pouring a quart of Amsoil Saber Two Stroke oil into his fuel tank the other day. It was an older Pete with a Pre Emission Cat. Didn't ask any questions. Who else is doing this? I'm guessing doing this to the new Urea engines wouldn't be a good idea....
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,723
    Jan 30, 2010
    keep stroking.
    nope it wouldnt be a good idea. on the pre emission it lubes the injectors. i do it every now and then.
  4. underpsi
    underpsi Road Train Member
    1,266
    291
    Sep 18, 2008
    Toronto, Ont
    Yup 2-stroke oil is one of the best things to put in the tanks as its made to be burnt (other then diesel fuel additives)
    Probably not a good idea with a DPF truck though.
  5. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    173
    Feb 21, 2010
    OZ - Brisbane
    Based on testing that I read once, exhaust emission were less when 200 to 1 mineral 2 stroke oil was added to diesel, so from that I would assume use of it on DPF will be ok
  6. gerardo1961
    gerardo1961 Road Train Member
    1,672
    480
    Feb 21, 2010
    miami
    My question is can i do this in my c13 acert(kcb)or not,when yes i have 120 gallon tanks,is 1 quart ok for each side
  7. Ewallace
    Ewallace Bobtail Member
    5
    1/2 oz per gallon is what we use.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,177
    Apr 20, 2011
    Dahlonega, GA
    I run a 50/50 mix of Power Service and 2 cycle oil in every tank. I use a quart bottle, put on bottle of mix in each tank. I buy the 2 cycle oil at Walmart in Gallon jugs.
  9. jimtx77
    jimtx77 Bobtail Member
    38
    Jul 31, 2011
    rafter77tx@gmail.com
    My mechanic recommended ATF in the fuel to provide lubricity??
  10. jimtx77
    38
    Jul 31, 2011
  11. standingtall
    standingtall Light Load Member
    64
    23
    Oct 31, 2012
    Doesn't it coat the fuel filters paper liner and make issues? Thats why almost all two stroke intank filters are made of a different material. And some only use a metal screen type filter on them. Just asking. Also wouldn't it change the color of the fuel and if you get dip tested they could say your running off road fuel? If not to the questions why not use a ashless oil two cycle like lawnboy used so it would all burn up instead of leaving a soot behind?
