2000 Freightliner Century Power steering intermittent
Discussion in 'Freightliner Forum' started by vics stuff, Sep 5, 2018.
  1. vics stuff
    vics stuff Bobtail Member
    30
    8
    Sep 5, 2018
    Hey Guys ! New to this forum. I am a owner operator and mechanic on my own truck.
    Today I started my truck after setting for a couple of months to move it for some maintenance that I want to do the truck. As I started to move forward , I noticed that the steering was very hard to turn, like no power steering. As i turned the wheel , all of a sudden the steering become easy like normal. I stopped turning and the steering became stiff again. As I manually turned the steering wheel back , the steering became normal again.
    As I rock the steering wheel back and forth , there is no power assist then it would start working correctly again.
    while the steering wheel is turning that direction. Every time I stop and start turning the steering is real stiff.
    The fluid level is fine. Everything was working fine when the truck was parked. I did notice some steering fluid started leaking out of the top of the steering box , steering shaft seal. Could I have a steering box valve issue ? That is what it feels like .
    any help for this owner mechanic would be appreciated.
    Vic
  3. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
    Drain and change filter in reservoir fill with red Dextron ATF should fix problem sounds like dirty filter gummed up. After it’s fixed if leak persists drain half fluid put Lucas ps leak fix should buy you some time. Worked for 3 yrs on my truck . Bought used box from junkyard for $100 4 yrs ago . Rebuilt box from shop in Ohio can’t remember name supposed to be good $600
    Expeditor Thanks this.
  4. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
  5. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
    Maybe kingpins are also dry
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    I put 15/40 oil in my old columbia. It healed the whinning. Dont own it anymore.
  7. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
    I’ve always wondered about that all the old trucks used oil. Best answer I can get is some do some dont. I like trans fluid cause it’s clean
  8. vics stuff
    30
    8
    Sep 5, 2018
    My issue is not with lack of front end lubricant. I completely service my truck every 5k miles. The front end is all new. I did not have any issues when I parked it 2 months ago after a long road trip.
    I will look at the resivoire filter and replace that and give it a try
    Thanks for the tip
    Vic
  9. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
    It’s been sitting just saying I sometimes notice an improve after grease
  10. vics stuff
    30
    8
    Sep 5, 2018
    I will try greasing the front also but seems real strange that the steering was fine when parked.
    Have used some Lucas additive in the system.
    Vic
  11. Rideandrepair
    17,494
    56,726
    Aug 8, 2015
    Makes sense filter was probably dirty. No one ever changes till there’s a problem I think I’ll change mine it’s been 6 yrs or so. Meanwhile it thickened up around filter.Same reason it will act up when cold lack of flow . First place to check otherwise the gear driven pump is bad easy fix either way.
