2000 International 9200. No trailer service brakes
Discussion in 'International Forum' started by Art Vandelay, Aug 23, 2019.
  1. Art Vandelay
    Art Vandelay Light Load Member
    141
    740
    Jul 31, 2019
    On my 9200, you can push the red button in. It releases the trailer brakes, but when you push the brake pedal or pull the trolley valve, it's not getting any service air to the trailer. so no trailer brakes at all.
    Anyone else had this problem or have an idea on where to start? I'm gonna start at the protection valve, and work backwards.
  2. stayinback
    stayinback Road Train Member
    3,395
    6,010
    Jan 24, 2014
    chicago,il
    Tractor protection valve. Most likely
    Heavyd Thanks this.
  3. Heavyd
    Heavyd Road Train Member
    6,622
    4,442
    Feb 4, 2009
    Pop your blue line off at the trailer and pull your spike lever and see if any air is coming out. Then follow your blue line. Some trucks have an in-line quick release valve right at the back of the cab, it could plugged, after that, like stayingback said, you likely have a bad tractor protection valve.
  • Draft saved Draft deleted
