2000 KW T800, when applying the brake right turn signal lights up
Discussion in 'Kenworth Forum' started by Lau, Oct 16, 2021.
  1. Lau
    Lau Bobtail Member
    I appreciate if someone can help. I have 2000 KW t800. When I step on the brake, the turn signal on the right front lights up. Also, in few minutes after I start to drive the position lights and the dashboard lights go out because the fuse burns out.
  3. kwcam
    kwcam Light Load Member
    154
    93
    Dec 29, 2012
    at the shop
    Unplug your trailer cord from the truck end and clean the socket, have seen it where corrosion has caused this issue. then see if it still does it with the cord unplugged.
  4. Lau
    Lau Bobtail Member
    Thank you for the answer and I will keep you updated at what will happen
  • Draft saved Draft deleted
