2001 Cummins N14 rough running/idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mission_creek, May 15, 2021.
  1. mission_creek
    mission_creek Bobtail Member
    26
    9
    Feb 22, 2021
    There are periods of time when the engine will run incredibly smooth and quiet. Then it will run rough like it’s missing a little or injector is knocking. Seems to run rough more often now. Would this be a wiring harness issue?
    Trucking Jobs in 30 seconds
  3. Heavyd
    Heavyd Road Train Member
    7,181
    5,336
    Feb 4, 2009
    I would suspect aeration of the fuel. This is typically caused by dry rotted fuel lines. Can be intermittent too. Sometimes the cam sensor can start to go bad but not bad enough to log a fault code. Certainly, bad or dirty electrical grounds can cause issues like this too.
  4. blairandgretchen
    9,330
    41,100
    Dec 9, 2011
    South west Missouri
    A running down the road cylinder cut out test may rule in/out injectors.
    I had a 2001 N14, 1.4 million is still strong with the new owner.
    Replaced injectors, fuel lines, cam and crank sensors. Ran great.
    Always had an intermittent stumble at idle - not sure why.
    A slight miss led me to have a Cummins tech go for a drive plugged in and perform cylinder cut out - weak on 2 , replaced all.
    John E. Thanks this.
  • Draft saved Draft deleted
