2001 T800 fan blower ?
Discussion in 'Kenworth Forum' started by Green461, Sep 15, 2024.
  1. Green461
    Green461 Light Load Member
    150
    93
    Mar 22, 2019
    Southern WI
    My heater/ac blower works ok, it would be nice to get it to blow more air. It just seems weak. Couple years ago I went through it all, replaced the blower and also the blower motor resistor at the same time. I just went through it again, its all clean, sealed up good, motor works great and seems powerful when removed and bench tested. However I had it all together and unplugged the resistor and it still worked. What is this resistor for? Trying to get this to blow really good. Alternative squirrel cage fans? motor? It just seems like it needs one more higher speed. Yet all 3 speeds work.
  3. Green461
    150
    93
    Mar 22, 2019
    Southern WI
    May have figured it out.. Resistor is used to cut power when switched to lower speeds. My connector looks like it got hot and melted some.. so im guessing its bad, and possibly the resistor..... ordered new resistor and connector... will see if it makes a difference.
    Stay Puft Thanks this.
  4. skallagrime
    skallagrime Road Train Member
    3,844
    9,897
    Apr 10, 2012
    Indiana
    When resistor is bad all positions are supposed to blow on high, in practice it sometimes burns your speed switch wires, but over time the blower itself can create heat in the wire, also if you never upgraded your box, may be worth it, much better airflow on updated blower and less likely to be rusted out when new (plus you can insulate it before install)
