2001 T800 Gear swap - how to change speedo?
Discussion in 'Kenworth Forum' started by Green461, Jul 27, 2026.
  1. Green461
    Green461 Light Load Member
    158
    106
    Mar 22, 2019
    Southern WI
    I swapped diffs in my 2001 Kenworth T800 and changed the gear ratio. Went from 3.90 to 3.36 and the shop I park the truck has a Matco scanner which we did successfully change it in the ECM, so my scangauge on the dash shows the correct speed... However my speedo is not correct. How do you figure out how to set the dip switches on the back of it? I just want my odometer to be accurate.
    Thanks.
  3. 062
    062 Road Train Member
    6,410
    34,272
    Oct 20, 2013
    Green461 Thanks this.
