2002 Freightliner Century Engine fan wont cut off
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thecubantrucker, Nov 9, 2025.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    Good afternoon guys this is a 2002 Freightliner Century with a 60s 12.7 pre-egr. Like the title says was driving home fan turned on during an small uphill wont disengage anymore. I changed the solenoid when parked engine off key off cant spin the blade when i turn on key can't spin it either like it wont disengage or even make a noise. Is there a way to check or do i need to look for power or jump some switches to test ajy help would be appreciated also no codes either.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    393
    428
    Apr 28, 2015
    Air leak? Either in the airline from the solenoid to the fan. Or in the fan hub itself.
  4. JB7
    JB7 Heavy Load Member
    957
    1,651
    Dec 13, 2022
    Laurel, MD
    Remove the air line going from the solenoid to the fan clutch. With the air up to 120 turn the key on and see if air comes out. It may be that the solenoid is not getting a signal and not sending air to the clutch. When the clutch gets air pressure it releases it allowing the fan to turn.
    If you have air coming out of the solenoid then check for leaks in the line and at the clutch after reconnecting it.
  5. thecubantrucker
    149
    92
    Jun 2, 2019
    So if air doesnt come out then it will be an electrical issue ??
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    Cant hear any
  7. freebeertomorrow
    freebeertomorrow Heavy Load Member
    922
    1,745
    Mar 19, 2016
    Indiana
    the 2020 mack i used to drive did this. the bracket for the fan wiring harness rusted in half and the wiring fell into the fan. defaulted the clutch fan to always engaged. (electrical issue)
  8. JB7
    957
    1,651
    Dec 13, 2022
    Laurel, MD
    Correct.
  9. thecubantrucker
    149
    92
    Jun 2, 2019
    Ok i did what you asked and yes the solenoid is getting the signal when i turn on the key air goes towards the fan clutch . So that leaves me to think is it the clutch or the hub itself ??
  10. JB7
    957
    1,651
    Dec 13, 2022
    Laurel, MD
    Yes, you are going to have to pull off the clutch and hub. There are videos online on how to rebuild yourself. Don't know what is on there but it may have auto lock which locks the clutch and fan when the friction material is worn out. See this.
    TECH TIPS – Auto Lock | Kit Masters
