I have been fighting this forever. I cannot figure it out and Im lost on further diagnosis. Its a 2002 Peterbilt 379
The governor is kicking in and purging air every 5-6min. ONLY when the engine is running, either idle or at speeding going down the road. I have gone through and fixed every leak I could find so far.
Airbags
Suspension leveling valve
Cab leveling valve
Governor
Check valve on passenger side air tank
Cleaned air dryer purge valve and replaced the o-ring. Air dryer is an approx 3yr old Bendix Ad-Sp and not cheap.
Now this is what throws me off. When the governor kicks in and purges the air at 130psi, if I leave the truck idling the purge valve will continue to bleed air to 120psi and the it stops. Takes about 20sec. Then it will slowly lead down to approx 110 psi and start building pressure again.
Now, if I shut the truck off before the gov kicks in say 125psi and leave the truck off, the truck will hold 125psi for hours.
Like Ive said, the only part I haven't replaced is the dryer.
What am I missing? What can I do to further diagnose this before replacing the dryer?
2002 Peterbilt 379 where is my air leak?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HillbillyDeluxeTruck, Mar 2, 2025.
Page 1 of 3
It actually could be the dryer, is it an ADIS? Is the govenor mounted on thr dryer?
Oxbow Thanks this. -
Oxbow Thanks this.
Since you say it's not losing pressure, I'd say unloader or dryer. That's just a guess with no real diagnosing though.
I vaguely remember having issues with a turbo valve once causing similiar symptoms now that I think about it.blairandgretchen, 4mer trucker, Oxbow and 1 other person Thank this. -
Is there a check valve in the air dryer? -
Engine fan? Solenoid feeds air when engine is running. Shuts off when key off
Oxbow Thanks this.
Oxbow Thanks this.
But I will double check it in the morning.
Edit: It seems the the solenoid and clutch are all 1 unit. So its been replaced in the recent past with a brand new Caterpillar part.Last edited: Mar 2, 2025
blairandgretchen Thanks this. -
Rereading your OP it sounds like a stuck unloader. The purge valve continues to leak because it continues to get a signal.Oxbow and HillbillyDeluxeTruck Thank this.
Page 1 of 3
