2003 kenworth no turn signal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Adamali21, Sep 13, 2021.
  1. Adamali21
    Adamali21 Light Load Member
    211
    132
    Jul 24, 2018
    I have a weird one
    driving down the road noticed my turn signal blinkers stopped working, no blinker light on the dash, trailer or truck, 4 way doesn’t work as well.
    then it would start working normally then stop working, it kept doing that all day yesterday and then today it just stopped working any ideas of where I should start
    2003 kenworth w900
  3. Ross_Tech
    Ross_Tech Light Load Member
    132
    129
    Aug 31, 2021
    Sounds like you aren't getting power to the switch, or the switch itself has failed.
  4. Adamali21
    211
    132
    Jul 24, 2018
    I am heading to kenworth I will start by changing the switch first, I don’t know if there’s a relay because I don’t see one on the fuse panel
  5. bad-luck
    bad-luck Road Train Member
    2,062
    3,163
    Nov 16, 2013
    Baltimore, Maryland
    Replace your flasher. Thats what happens when they go bad.
    Ross_Tech and Adamali21 Thank this.
  6. Adamali21
    211
    132
    Jul 24, 2018
    Does anyone know where that flasher is located
    It’s not on the fuse panel
  7. Ross_Tech
    132
    129
    Aug 31, 2021
    Yea, that too. I'm used to newer trucks with modules that control the turn signals....haha
    Adamali21 Thanks this.
  8. Adamali21
    211
    132
    Jul 24, 2018
    So I got to the KW dealer changed out my turn signal switch and flasher. Hope it does the job.
  9. Adamali21
    211
    132
    Jul 24, 2018
    So once I stop at the dealer the turn signal started working randomly, after changing those two parts and I started heading down the road the turn signal stopped working again
    now I am clueless
  10. Super_Trucker
    Super_Trucker Bobtail Member
    20
    58
    Feb 6, 2020
    Central Texas
    I know it's after the fact but for future reference the flasher is located in the dash behind the ingnition switch if you remove the small rectangular dash panel bearing the Ingnition switch on the left side of the steering wheel
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    3,617
    5,030
    Aug 26, 2014
    I thank your fuses are in front of your clutch pedal. If so look closely at the connectors in the block.
  • Draft saved Draft deleted
