2003 w900 no trailer brake lights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Adamali21, Dec 4, 2024.
  1. Adamali21
    Adamali21 Light Load Member
    267
    172
    Jul 24, 2018
    Hello I have a 2003 w900 i am having no brake lights to the trailer, I checked the trailer stop fuse and it’s not getting power. Is there something else I should check
  3. MM71
    MM71 Heavy Load Member
    757
    985
    Jun 28, 2008
    AZ
    Relay and fuses on firewall under hood, usually somewhere on the upper drivers side by the windshield fluid reservoir.
  4. Adamali21
    267
    172
    Jul 24, 2018
    Does an 2003 w900 have a fuse or relay on the firewall under the hood I thought only the 2000 and under did.
  5. D.Tibbitt
    134,311
    If you have a blown Fuse then you have a brake light wire that is shorting out somewhere.. check the wiring around your brake lights to see if there is some exposed wiring touching the frame... that is the best place to start...
    replace the fuse and see what happens
  6. Adamali21
    267
    172
    Jul 24, 2018
    The fuse is not blown it’s just not getting power
    D.Tibbitt Thanks this.
  7. D.Tibbitt
    134,311
    Ok if it doesn't have power to the fuse then check the wiring going into the fuse block itself
