2004 379 Pete. Can't get fuel tanks to feed equally.
Discussion in 'Peterbilt Forum' started by drummroya768, Jun 4, 2025.
  1. drummroya768
    drummroya768 Bobtail Member
    Sandman,
    So I've got fuel problem on a 2004 379 Pete, 500 acert cat.
    Fuel only feeding off passenger fuel tank, keeps left fuel tank overfilled constantly spewing out of cap vent. All new feed, return lines, tank vents, splitter valve replaced 4 times, new pickup tube in driver tank, still having same problem. HELP!!!
  3. drummroya768
    I've been reading prior threads on here about this problem and I'm going to start my own diagnostic by taking one line at a time off from splitter and top return on tank and blow pressure through to make sure no blockage. I'm going to do the return to passenger tank first seeing nothing comes back to that tank. Then next my feed line from left tank to 3 way feed fitting. So on.
    If anyone has a better idea or cure for my problem, I'm open to all information and would really appreciate your feedback.
    Thanks, Sandman.
  4. Lazer
    Lazer Road Train Member
    1,836
    2,961
    Jan 22, 2017
    Is the splitter valve adjustable?
  5. Big Road Skateboard
    6,783
    38,185
    May 2, 2021
    Well, it's either not pulling fuel from, or returning more to, the overfull tank.
    Drop both return lines to a 5 gal bucket first and see if return is equal. Then we can go from there
    wore out Thanks this.
  6. wore out
    wore out Numbered Classic
    16,888
    207,108
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The lines to the splitter on suction and return have to be the exact same length as well as pitch. Same size internally etc. if one has more rise that the other you have trouble
    ‘Olhand Thanks this.
  7. kemosabi49
    10,919
    47,434
    Jan 13, 2013
    SW Arkansas
    I had a FLD that had the fuel line from the tank got plugged with some crap inside the tank. Then the return line would end up overflowing the tank. Shop ended up connecting the fuel line to a portable pump and found that it could not get any flow from the tank. They pulled tank and sent it somewhere for cleaning.
