2004 Columbia (no power no speedo)
Discussion in 'Freightliner Forum' started by hicksd67, Feb 1, 2012.
  1. hicksd67
    hicksd67 Bobtail Member
    Phoenix, Arizona
    Have a 2004 Freightliner Columbia, CL12064S, with a Detroit series 60, and a Fuller 10 speed. Several times recently, while driving with a full load, on flat ground, the speedometer will suddenly quite working and the truck will loose power. It acts like it is in a "power down" safety mode of somekind, allowing the vehicle to travel at limited power (20 mph). There are no warning lights on the dash, and the oil pressure, engine temperature and voltage are in normal ranges.
    If you shut it down and restart it everything seems to work fine. No need to wait for any period of time before restarting either.
    There are no Diagnostic Trouble Codes in the system, in history or active.
    Any thoughts?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    when VSS reads wrong speed Engine ECM limits power and max. rpm.
    Usually there is bad connection on VSS (rear end of tranny)/. inspect wiring and connector. Cleane it
  4. hicksd67
    Phoenix, Arizona
    Wouldn't that cause a Diagnostic Trouble Code that would be able to be seen as either ACTIVE or INACTIVE. We are getting zero codes. None.
  5. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
  6. Giggles the Original
    Giggles the Original Road Train Member
    6,761
    107
    Jun 11, 2010
    looking for a new stalker
    speedo???? bad mental image...bad...LOL
