2004 international 4300 Allison transmission identification
Discussion in 'International Forum' started by Rk111, Jun 16, 2020.
  1. Rk111
    Rk111 Bobtail Member
    4
    Hello. I recently purchased a 2004 4300 with dt466 195 hp and automatic transmission. I can't read the transmission tag. It's a 5 speed overdrive with manual shift selection and it has a park position, hyd brakes, which model transmission is this. Thanks
    Trucking Jobs in 30 seconds
  3. QUALITYTRUCK
    1,554
    1,412
    Jun 14, 2009
    romulus,mi
    Call dealer parts dept.with last 8 of vin#, or post it here and if HeavyD is in a good mood he will be able to find the info that you need........
    Heavyd Thanks this.
  4. Flint1
    Flint1 Medium Load Member
    472
    3,807
    Sep 4, 2019
    Alberta
    More then likely and Allison 1000 or 2000 series.
    At545 and mt643 were 4spds and obsolete by then. 3000 series has an electronic shifter
  5. Rk111
    4
    Thanks for the info. I suspect it is a 2000 series but which one? Some posters say it's the light duty model due to park position but that may have been standard with hyd brake.
    Vin # 4h593800
  6. Rk111
    4
    Also, like everyone else I could use more power. It says 195. Is it possible to plug and play a used ecm. That's half the price of a questionable aftermarket tune.
  7. Heavyd
    Heavyd Road Train Member
    7,151
    5,310
    Feb 4, 2009
    Allison 2400. Not sure about the ecm though.
  8. Rk111
    4
    Thank you. Will a Alison 2400 hold up to a gcvw of 30-35k on a regular basis
  9. Heavyd
    7,151
    5,310
    Feb 4, 2009
  10. Brandonmc89
    Brandonmc89 Bobtail Member
  11. owenzhou
    owenzhou Bobtail Member
    15
    Feb 10, 2014
    ALLISON 2500 RDS
    Brandonmc89 Thanks this.
  • Draft saved Draft deleted
