2004 SVCC 6-7 CAR TRAILER
$35,000 o.b.o.
$10k worth of under-body welding done recently.
Top-side recently painted
Car Hauler
Road Ready
The information below is from the manufacturer - spec sheet from when the trailer was originally purchased (not by me - I bought it used) Information is not guaranteed - buyer to verify specifications for themselves.
22,500 LB DANA AXLES --- with dust guards
77.5" wide track drum to drum & 50" spread on axles
ABS AIRBRAKES/ RIDEWELL AIR RIDE SUSPENSION
ABS system uses Meritor WABCO products
CENTER TURN SIGNALS
53 FT UPPER DECK/ 47 FT LOWER DECK
RATCHET ASSEMBLIES standard--- includes bolt on chain/hooks
SELF CONTAINED HYDRAULICS (pump/motor assembly)
ALUMINUM CYLINDERS
HYDRAULIC LOADING RAMPS ON REAR OF TL -- using 2.5 bore cylinder
HYDRAULIC TILT/FRONT END--7' ramps 3 ' allowed for load extensions
REAR FLIPPERS ON UPPER DECK -- aprox. 2ft extensions
255/70R 22.5 RADIAL TIRES
STEEL WHEELS INNER
POLISHED ALUMINUM WHEELS OUTER
COLOR OF CHOICE --- Dark Black
enclosed front of trailer to protect hyd set up
new style wiring harness
skid plate under rear bumper --- out of 1/2x6" flat plate
Please text prior to calling, as I rarely answer calls
two-2-four, 2-five-4, four-3-four-7
2004 SVCC 6-7 CAR TRAILER Sunvalley
Discussion in 'Trucker Forum Classifieds & Trading Post' started by Pht1991, Mar 5, 2021.
