2005 Columbia Detroit governor at 65MPH - How can I increase speed
Discussion in 'Freightliner Forum' started by D&Ptrucking, Feb 21, 2015.
  1. D&Ptrucking
    D&Ptrucking Bobtail Member
    10
    Oct 26, 2014
    Just bought a Ryder F.L. in December - got a governor on it at 65 MPH - anyone ever increased the speed>. Wondering if its something I can do myself or have to take in to a Freightliner Specific garage.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,635
    Oct 11, 2010
    Borispol, Ukraine
    Use DDCT ore DDDL software. To get the ECM password - call detroit hot line)!
  4. Riprap
    Riprap Light Load Member
    286
    1,978
    May 31, 2014
    Saginaw, MI
    A genuine Detroit Diesel shop like Williams or Clarke can set it up however you want in about 5mins, its all controlled in your ecm so they will hook it up to their computer.
  5. EZ Money
    EZ Money Road Train Member
    Ryder should have gave you the password to begin with.
    Ryder turned some up for us when my former company bought them.
    No charge....takes all of 5 minutes.
    Also some ECMs have two different horsepower programs that can be used.
    They were put on the ECM when they come out of the factory.
    If it is a Detroit it probably has a 435 and a 515 HP setting.
    If it is a Ryder I would ask about disabling all the BS like progressive shift too,set the RPM where you want it and all.
    They turned the one I had up and used the higher HP setting....what a different truck!
    It got better mileage too.
    KB3MMX and Oldironfan Thank this.
  6. Verdel
    Verdel Medium Load Member
    582
    128
    Oct 26, 2013
    Detroit Diesel, not Freightliner is the place to go. I paid $120 for unlocking the speed limit and set the correct size of tires.
    Oldironfan and Dave_in_AZ Thank this.
  7. Jetsr6
    Jetsr6 Light Load Member
    131
    42
    May 20, 2011
    Mechanicsville, VA
    Drive 55 and then you don't have to worry about it. And save 10000 a year!
    KB3MMX, Dave_in_AZ and cstefan Thank this.
  8. Alan Brechbiel
    Alan Brechbiel Bobtail Member
    39
    7
    Jul 22, 2015
    Also depends on your ratios. With 370 rears your max speed will be about 72. With 355's you could max at 80 mph. Your highest MPG will be found around 1,400 RPM. Find out how fast your truck goes at 1400 RPM and have the Governor set there for high profitability.
    KB3MMX and Dave_in_AZ Thank this.
  9. terryt
    terryt Heavy Load Member
    726
    756
    Apr 27, 2009
    Go back to Ryder they will do it for free. Like other said have all password and passcode removed. Can have shut down timer turn off
    Dave_in_AZ Thanks this.
  10. mhyn
    mhyn Road Train Member
    4,255
    4,483
    Dec 29, 2008
    Northridge, CA
    dddl plus backdoor password generator..))) no need to go to DD official dealer..)))
  11. QUALITYTRUCK
    1,698
    1,621
    Jun 14, 2009
    romulus,mi
    Hey mhyn! How do I get that backdoor password generator? Would help me a lot!
    KB3MMX Thanks this.
  • Draft saved Draft deleted
