2005 Mack CV713, lightning Bolt
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Unit12, Sep 18, 2020.
  1. Unit12
    Unit12 Bobtail Member
    I have 2005 Mack CV713 with an 8LL trans, the lightning bolt symbol comes on at various times. It normally comes on when pulling hard or a major bump in the road. Also, it will go off on a bump in the road. When the light is on, I switch off the cruse and push the speed set button, if the the speedometer is still working I get 7-1 code. (service brake switch) If the speedometer is not working (which is most of the time) I get 4-1 code. (speed sensor) Now, while driving with the cruse on and set at any highway speed, the cruse shuts off when the lightning bolt comes on. I have replaced the speed sensor and pulled it after running for about a week the make sure it was still good. When the light is off the truck runs like it should. Any suggestions?
  3. Judge
    71,428
    It’s an electrical issue, the dealers hookup can tell you the exact thing giving problem.
