2005 Volvo with volvo engine wont start, Injectors 1-6 code mid128 sid1 fmi5
Discussion in 'Volvo Forum' started by Breathless, May 9, 2020.
  1. Breathless
    Breathless Bobtail Member
    7
    Jul 5, 2019
    D12 engine Need help. It cranks but does not start. looks like issue with the injector circuit. Codes in ecu 1 to 6 injectors. Mid128 sid1 fmi5. Plus the same mid128 and fmi5 plus sid1-6 code. What could it be? Help!
    DmitriyKW Thanks this.
    Trucking Jobs in 30 seconds
  3. nasriza
    nasriza Road Train Member
    2,101
    1,684
    Feb 1, 2013
    Chicago, IL
    Check wires on batteries ecm is not getting enough power to turn on injectors.
  4. Breathless
    7
    Jul 5, 2019
    Where would I check that. Is it a pin on the ecm connector that powers the ecm?
  5. nasriza
    2,101
    1,684
    Feb 1, 2013
    Chicago, IL
    Check the wires on top off batteries for corrosion. Not the big one the small ones.
  6. Breathless
    7
    Jul 5, 2019
    I did check it. Its a red and a white wire. They have good power and not corroded
  7. Breathless
    7
    Jul 5, 2019
    I have looked online and something called EMS2 comes up. Not sure what that is? Would you know which pin to check and connector for the + power for the injectors?
  8. nasriza
    2,101
    1,684
    Feb 1, 2013
    Chicago, IL
    Check the engine management fuses in the cab there should be 2 of them.
  9. Breathless
    7
    Jul 5, 2019
    Would they be in the fuse box or under the dash?
  10. nasriza
    2,101
    1,684
    Feb 1, 2013
    Chicago, IL
    it would be in the fuse box make sure to check all fuses have power with ign on maybe some relay if messing up and making all kinds of problems for you.
  • Draft saved Draft deleted
