2006 Freightliner Columbia - dash blower motor not working
Discussion in 'Freightliner Forum' started by ds1989, Nov 16, 2014.
  1. ds1989
    ds1989 Light Load Member
    54
    38
    Jul 24, 2014
    Kansas City, MO
    The blower motor quit working all of the sudden the other day. No warning. Checked the 5 amp and 30 amp fuses in fuse panel. Bunk blower motor works. Doesn't matter what position I place the fan speed switch. Took the front cover off the dash to reveal the blower motor, but can't even tell how to remove it. Pretty compactly installed.
    Does this sound more like a resistor? Or did the blower motor just simply give out? Tried searching videos on YouTube, found what seems to be the one and only video, but doesn't match up to the configuration in this truck.
    Any thoughts/input would be greatly appreciated. Thanks.
  3. EZX1100
    EZX1100 Road Train Member
    4,016
    5,703
    Aug 18, 2012
    two things
    one, the motors are interchangeable, i prefer the rear over the front (it has already happened to me)
    two, my front fan takes a break in the middle of the day, for about an hour, then comes back on
    gremlins maybe? anyway, freightliner wants an arm and a leg to figure it out
    i have learned to live with it
  4. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
    Thanks for the info. Good to know.
  5. zenaddler
    zenaddler Light Load Member
    158
    130
    Nov 7, 2013
    Make sure your switch is good. They go out.
  6. RSQ20
    RSQ20 Medium Load Member
    You have heard of test lights and meters, get one and check the power at the dead motor..
    If power, then motor is dead..
    If not, look upstream..
    ... Philip
    Jimmbuds Thanks this.
  7. porkchop_express
    porkchop_express Bobtail Member
    28
    14
    Oct 17, 2013
    The problem is going to be either the control switch assy, the harness from the switch to the motor, or the motor itself.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,620
    Oct 11, 2010
    Borispol, Ukraine
    wait a minute! Behr switched to brushless motors in 2005 so u can have brushless motor with mounted on it ESC, and u may have bad circuit on board if bearings are old and motor consumps too much current
  9. angelor
    angelor Bobtail Member
    40
    May 22, 2013
    That year and thru 2010 is notorious for wires shrinking. Our whole fleet pulled right out of fuse box on fender over time. Check for power right at blower motor.
  10. Robbys Rollback
    Robbys Rollback Bobtail Member
    I've got a 2005 Freightliner M2 Buiseness the blower motor was not work when I bought the truck so I've replaced the Motor with new stall wiring harness I'm getting power to the motor the volts go up and down with the switch so the control can't be bad what now
  11. RSQ20
    You have confirmed power in, now fix the ground...
    ... Philip
  • Draft saved Draft deleted
