2006 Kenworth W900 low pressure light works but buzzer does not
Discussion in 'Kenworth Forum' started by Cindy, Jan 10, 2026.
  1. Cindy
    Cindy Light Load Member
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Hi, I have a 2006 Kenworth W900 I put a new low pressure switch in, I bought a buzzer for the low air pressure the buzzer stays on. I pushed the parking brake in the buzzer goes off, I pull it out and the buzzer goes on. I drained the tanks, I pulled pressure switch out started the truck up. No air comes out as its building up air pressure. I pushed the parking brake back in and air comes out.
    Thanks all help is appreciated.
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,835
    75,747
    Dec 9, 2011
    South west Missouri
    (Not a mechanic - but)
    Check that the pressure switch you replaced is the same - it should have a stamping or marking somewhere that says . . . (it's often on the brass nut part)
    NO (Normally Open) or
    NC (Normally Closed) -
    A NC switch will have the buzzer working, until pressure is supplied at 60 PSI or so. Then it becomes an 'open' circuit - removing power to the buzzer.
    A NO switch will be the reverse - the buzzer will be off till the pressure hits 60 PSI or so, then it will 'close' the circuit, supplying power to buzzer.
    That's all I got.
    Oxbow Thanks this.
  4. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Thanks, I really appreciate it.
  5. Big Road Skateboard
    6,951
    39,255
    May 2, 2021
    Sounds like someone has put the wiring and/or low pressure switch in the wrong port in the manifold.
    The ports for the buzzer and light will always have pressure.
    Oxbow Thanks this.
  6. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Thank you, appreciate it.
    Oxbow Thanks this.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,562
    9,924
    Mar 30, 2014
    I'm a little confused. My buzzer and light are a module. The buzzer didn't work, but the light did. I changed the module because the fan light didn't work. When I changed it, the buzzer now works. I know that the part I put supersedes the one that was originally in mine, so it definitely covers later years than mine. If mine has the buzzer in the same assembly as the lights and the buzzer is not serviceable, wouldn't yours be like that too? 1994 for your information.
