2007 E engine nrockershaft pedestal bolts breaking
Discussion in 'Mack Forum' started by mackjack2007, Feb 5, 2015.
  1. mackjack2007
    mackjack2007 Bobtail Member
    has anyone had an issue with rocker shaft bolts breaking and causing cam damage
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,594
    6,697
    Aug 26, 2014
    Never saw or heard of it and my minds eye cannot see it either. Wonder if shaft bolts were over tightened and stretched or wrong ones. It could possibly be seen on the ones that are not broken or compare length to new ones. Could the cam damage have been a work already in progress? If bolts broke one by one possibly engine ran for a period of time with excessive valve clearance. Clearance allowed lifter to slap or skip on cam with resulting damage. Or if clearance was extreme possibly rim of push rod cup contacted bottom of adjusting screw. This could result in a valve hitting a piston during valve overlap and crashing the cam and lifter. Since you own an E7 you probably already know the older ones had lots of cam problems. I believe that was pretty well worked out long before 07 but they probably have a low tolerance for things like incorrect adjustments. Had any work done lately?
  4. dick sachs
    dick sachs Bobtail Member
    5
    Feb 15, 2016
    yes just had rocker shaft bolt break on one of our trucks and caused cam damage.
    BoxCarKidd Thanks this.
  5. BoxCarKidd
    4,594
    6,697
    Aug 26, 2014
    Excuse me mackjack: Just had a book out looking for something for someone else and found service bulletin SB213043. It had to be part of a cam or engine kit because it is just stuck in the book.
    Use revised rocker shaft mounting bolt 416GC23M and torque to 45lb-ft.
