Looking to purchase the beast described above. I gave a 500 deposit to hold for four weeks.
I went a couple days before my hold expired to check it out real good.
It started right up after sitting those four weeks, but while giving it a thorough looking over and it idling for about 20 minutes the check engine light started blinking. It seemed odd to me that it would go away if I pressed on the gas pedal only to returned after a couple minutes at idle.
Does anyone know what the issue might be?
It does have 1.2 mill on it and was informed it has only been given injectors recently.
No rebuild ........
Everything else on the truck seems to work and runs fine with good oil pressure. I didn't take it out on the road as sales was closed, but noticed the key in it. Engine looked dry with no visible leaks.
Brand new virgin rubber for 11k, its a single axle
Thank You In Advance For Your Time)
2007 Freightliner Columbia 120 w 14L Detroit n 10 spd man, check engine light blinks after long idle
Discussion in 'Freightliner Forum' started by pfflyer, Nov 28, 2021.
