2007 Freightliner Columbia 14.0 liter Detroit flash code explanation?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hulld, Dec 14, 2019.
  1. Hulld
    Hulld Road Train Member
    2,105
    4,082
    Oct 19, 2015
    Upstate NY
    I have a flash code of 25 on the red engine shut down light which I believe means no active codes ?
    On the yellow check engine light I have flash codes 39, 23, 47, 22.
    Every thing seems to be running fine at this point.
    Do any of these flash codes on the yellow check engine light have any relevance at all?
    Or are they just left over codes from previous issues?
    Also is there a way to clear theses codes with out Detroit Diesel software?
  2. CGYMIKE
    CGYMIKE Bobtail Member
    5
    Calgary
    Im replying to this as well just to see if anyone finds a solution for this
  3. Hulld
    2,105
    4,082
    Oct 19, 2015
    Upstate NY
  4. Hulld
    2,105
    4,082
    Oct 19, 2015
    Upstate NY
    I am blown away that 81people have viewed this thread and not one person has an answer?
    This must be like super secret Freightliner information lol
  5. nikmirbre
    nikmirbre Road Train Member
    2,872
    3,495
    Jul 27, 2011
    Concord,NC
    The flash 25 means everything is good...... probably left over codes from before.
    Hulld Thanks this.
  6. nikmirbre
    2,872
    3,495
    Jul 27, 2011
    Concord,NC
    that code 39 is....I can't remember what exactly freight liner told me at the time but there's no cure for it....
    Hulld Thanks this.
  7. QUALITYTRUCK
    1,256
    908
    Jun 14, 2009
    romulus,mi
    These numbers are flash code numbers that need to be broken down further. Ex: 39 is a under/over boost problem that could be turbo or egr related. DDDL 6.45 is needed to properly troubleshoot.
    spsauerland and Hulld Thank this.
  8. Hulld
    2,105
    4,082
    Oct 19, 2015
    Upstate NY
    I was just wondering if the yellow check engine light flash codes are considered active or not?
    And also wondering if they can be cleared with out Detroit software?
    I believe the code 39 stems from an issue I had with the vpod sticking.
    When that event occurred it buried my 50 lb boost gauge.
  9. QUALITYTRUCK
    1,256
    908
    Jun 14, 2009
    romulus,mi
    They will be inactive. If active, check engine light would be lit. Bad vpod would throw 39 code. Don't remember if you can clear without device. Don't think so, but I may be wrong.....
    spsauerland, Hulld and nikmirbre Thank this.
  10. Hulld
    2,105
    4,082
    Oct 19, 2015
    Upstate NY
    Thank you.
  • Draft saved Draft deleted
