2007 t600 with ISX has a bad turbo bark and low power on incline
Discussion in 'Kenworth Forum' started by jpx2, Oct 15, 2026.
  1. jpx2
    jpx2 Bobtail Member
    39
    9
    Apr 24, 2026
    i have a 2007 t600 with the cummins ism and eaton ultra shift we have just bought the truck and built it into a custom flat bed or delivering campers cross country. i am getting a bad turbo bark and low power on the slightest incline and sometimes even on flat ground when trying to speed up.alot of what i'm finding says lifting off the gas to quick will cause it but it's happening with the cruise on even when the truck was empty. so far i did find a hole in the air line to the turbo and replaced it then i was getting a code for the turbo air valve and replaced it. the check engine light is off and no other codes. any ideas what i should be looking for next? my truck weighs 22k so there is no way fully loaded trucks should be able to fly by me up hill when i can't even maintain 65mph.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,186
    5,846
    Mar 18, 2021
    St Malo mb
    Get Cummins to diagnose it . I drove a 410 hp ism in 2000 it was notoriously weak our loads were 7/8000 lbs putting us at 37)38000 lbs we got passed steady in the mountains. PS many are set in the 350 to 370 hp range amazing on fuel but weak power and jakes..
  4. fromAtoZ
    fromAtoZ Light Load Member
    269
    647
    Sep 19, 2026
    Phoenix
    How old is the charge air cooler? Maybe leaking. Pressure test it.
  5. jpx2
    jpx2 Bobtail Member
    39
    9
    Apr 24, 2026
    ti'm not sure on the age we just bought the truck but the intercooler had been replaced as the old one was still in the back when we bought it. i'm thinking about unplugging the egr valve and finding a hill to see if it get's any better i was also thinking about rebuilding the turbo but the label is missing so i'm not sure what model it is yet
  6. fromAtoZ
    269
    647
    Sep 19, 2026
    Phoenix
    I'd still pressure test the CAC. Even new ones can leak.
  7. jpx2
    jpx2 Bobtail Member
    39
    9
    Apr 24, 2026
    ok any advice on to pressure test it? it's a 3 or 4 inch hose whats the best way to plug it up and how many psi ?
  8. fromAtoZ
    269
    647
    Sep 19, 2026
    Phoenix
    Cummins ISM pressure it up to 30psi, if it drops more than 5psi in 15sec, it's bad.
    You can search CAC pressure test kits online. Or make your own. Check YouTube on that.
    Magoo1968 Thanks this.
  9. wore out
    wore out Numbered Classic
    18,394
    234,179
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A CAC isn’t gonna cause turbo bark. While it will cause low power and poor fuel economy.
  10. jpx2
    jpx2 Bobtail Member
    39
    9
    Apr 24, 2026
    we've only had it on the road for 8000 miles so far and are averaging 9.3 mpg and i haven't seen a single puff of smoke out of the tailpipe. in 2nd thru 8th gears it pulls hard then 9th is ok then 10th it falls on it's face. it doesn't have a boost gauge yet but to me if feels like it's not getting any boost in 10th gear when the bark happens i can drop it to 9th and whined it out almost to 2000 rpms and it pulls strong but when it upshifts most of the time it will start barking again.the truck had been sitting for 2 years before we bought it so i was hoping it was just something stuck. i was in wv last week and at times had to drop it all the way down to 5th to get up the mountains.
  11. fromAtoZ
    269
    647
    Sep 19, 2026
    Phoenix
    The ISM likes to "bark", so I was thinking the low power is the issue with CAC leaking. I got so tired of cheap manufactured ones, I ordered an aftermarket CAC from Pittsburgh Power for my Cat 3406E.
    I guess the next thing to check on the ISM is turbo shaft play and sticking turbo vanes. Of the turbo is ok, look into the tuning (trim codes may be off), or maybe wrong size turbo. I guess you're gonna need a Cummins mechanic for that.
