2007 Volvo D12 coolant in oil
Discussion in 'Volvo Forum' started by D12 Owner, Apr 16, 2018.
  1. D12 Owner
    D12 Owner Bobtail Member
    29
    Apr 16, 2018
    Hi just got an oil sample tested and it said I have seriously high coolant in the oil. I have been having to add a quart every week, nothing too alarming and my water pump is very slowing leaking around the housing so I thought that was it. Can a bad water pump put coolant in the oil? Truck runs fine, no odd smoke or noises, starts great, no oil in coolant tank, coolant looks perfect, nothing coming out the overflow cap. I know one of the possible causes is the egr cooler but it has been disconnect for awhile so thats not it. What are other possible causes? And can anyone recommend a good place to get a d12 overhauled (even if its been slightly de-emissioned)? Scared to death buy a newer one with all the problems they have been having.
  3. RSB34
    RSB34 Light Load Member
    272
    191
    Feb 9, 2013
    ny.
    In my cat Accert I had the same problem we thought I needed a rebuild. They took the pan off and found the water pump was the cause it was leaking internally. I am not sure about the Volvo engine but it may be possible. Get it checked out asap that will kill the bearings fast.
    D12 Owner Thanks this.
  4. D12 Owner
    29
    Apr 16, 2018
    Thanks for the information, most mechanics I talk to today said on the Volvo D12 the water pump is seldom the cause, more then likely a piston liner (great...)
  5. RSB34
    272
    191
    Feb 9, 2013
    ny.
    I'm sitting here figuering what to do with my engine and truck. Cummins just gave a estimate of $45,000 to rebuild. So your not alone. Good luck
  6. D12 Owner
    29
    Apr 16, 2018
    I know it's a headache for sure, what year of truck?
  7. RSB34
    272
    191
    Feb 9, 2013
    ny.
    1999 I going to put a used engine in it. No way I can pay that kind of money
  8. Mudman78
    Mudman78 Light Load Member
    106
    102
    May 23, 2016
    The waterpump is possible, but not likely. It's not the EGR cooler. There's no oil flowing through the cooler. Only coolant and exhaust. Probably injector cups. Pull the valve cover and see if there's traces of coolant around the injector bores.
  9. LeeJackson
    LeeJackson Bobtail Member
    30
    17
    Apr 8, 2015
    Santa Fe Springs, CA
    $45K for a rebuild? Ouch! What year? Seems very high. You should be able to swap for a reman engine for about half that.
  10. RSB34
    272
    191
    Feb 9, 2013
    ny.
    It's a 99 I'm swapping engines. Local shop said rebuild be around $25k that Cummins are nuts. I found I low mile used engine I'll get that in for right around $12k.
  11. LeeJackson
    30
    17
    Apr 8, 2015
    Now that makes sense!
    D12 Owner and RSB34 Thank this.
  • Draft saved Draft deleted
