2007 Volvo VT830 D16 535HP, changing rear axles ratio from 3:55 to 3:36
Discussion in 'Volvo Forum' started by sbreeden, Nov 17, 2019.
  1. sbreeden
    sbreeden Light Load Member
    73
    55
    Dec 15, 2016
    Since I only pull less that 30k dry van, cruising at 65mph at 1475RPM w/18 speed trans, is just blowing my profit out the stacks.
    Volvo data sheet states with a 3:36.1 rears with .74 in 18th gear, cruising should be at 1350, to me that's ideal
    Have anyone did this swap and how did it turn out?
    KB3MMX Thanks this.
  3. 062
    062 Road Train Member
    5,839
    31,562
    Oct 20, 2013
    If you’re running lo pro rubber,switching to tall rubber will get you pretty close and a lot cheaper.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,600
    Jan 1, 2014
    If your going through the expense of changing rear ends I would go down in the 264 range. That 336 just won't make that big of a difference.
    KB3MMX and DUNE-T Thank this.
  5. AModelCat
    144,554
    What little fuel economy you might gain vs the cost of re-gearing is most likely a waste of time. I'd just run it until a diff is ready to blow and do it then.
    Socal Xpress and DUNE-T Thank this.
  6. tnevin225
    1,166
    1,600
    Jan 1, 2014
    What is your current fuel economy? I think the problem might be more the D16 than the rear ends. And does the truck match up to the trailer or is it a mid roof.
    loudtom Thanks this.
  7. DUNE-T
    DUNE-T Road Train Member
    6,366
    14,939
    May 10, 2015
    Detroit, MI
    I tried this experiment and my mpg got worse due to the tall rubber
    AModelCat Thanks this.
  8. DUNE-T
    6,366
    14,939
    May 10, 2015
    Detroit, MI
    Double this
  9. 062
    5,839
    31,562
    Oct 20, 2013
    You most likely didn’t need to drop rpm’s as may be the case with the op.
  10. AModelCat
    144,554
    I think you nailed it. No need for a big 16L engine when you aren't even pulling legal weights.
  11. sbreeden
    73
    55
    Dec 15, 2016
    I'm getting 5.5 hilly, flat 6.3, I got a good deal on the truck, no issues for $23k. I didn't think much about mpg when getting it, just that I could pay for it out right. Now that I'm pulling it and seeing half my settlements going out the stacks, it becoming more of a burden than a money maker. I can get a set of rears that match the trans for $2000, then have the speedo reprogram.
    It a mid roof, I order the roof wing last week, running tall tires.
    Just fishing for ideals for make the more efficient.
    Thanks
