2008 mbe4000 erg cooler replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chrcun, Nov 21, 2013.
  1. chrcun
    chrcun Bobtail Member
    4
    Kingston,ont.Canada
    I've had my 2008 sterling with a MBE400 13 speed 3.90 gears. Has Anybody have problems with egr coolers. I have replaced 4 now and I just
    had that one go within just under 6 months. Has anyone else had this problem or is it just me!!!!!!!!
    Detroit wants nothing to do with me saying they don't have this problem anywhere else. Is it my luck or are they just not admitting a problem.
    By the way I only have just under 800k. Just throwing it out there
    THANKS:biggrin_25512:
  3. HeWhoMustNotBeNamed
    HeWhoMustNotBeNamed Crusty Pogosticker!!
    3,454
    19,721
    Jan 25, 2012
    Cartoon Network
    This Post definitely belongs in the Garage forum. Lets see if we can get it moved for you by a Mod. Good Luck !
    chrcun Thanks this.
  4. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    I went through.....ONE on my 2006, in 884k miles.
    So it is indeed not a common problem. I think I have a spare one, from a motor I tore apart, at home.
    What is it doing exactly? Leaking into the intake?
    I blocked mine off, at both ends, so if it leaked, it couldn't enter the motor.
    Martin
    chrcun and The Challenger Thank this.
  5. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    have serviced a fleet (15) for 6 years.have had 1 leak 2 years ago.replaced.no further problems.
    chrcun Thanks this.
  6. chrcun
    4
    Kingston,ont.Canada
    Thanks To All For Your Thoughts And Input. There Is A Shop that wiill reprogram my ECM so that it over rides the DPF symtem,But I have to replace the Cooler First. I am a little reluctant To, but I Know of People Who Have And It Works Great.
    GOT TO GIVE THIS SOME MAJOR THOUGHT
  7. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    My 2006 was blocked off for too many years to count, worked great.
    See if they are the same, if so, how about $50 plus shipping for the cooler from my old motor?
    Martin
    chrcun Thanks this.
  8. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    One possibility with repeat failures of EGR coolers is improper installation. If it is installed slightly misaligned, once all the connections are bolted in place the cooler body will be stressed and prone to cracking. Over torquing fasteners is an easy way to over stress them as well.
    chrcun, QUALITYTRUCK and 25(2)+2 Thank this.
  9. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    is it possible to do it when its time to replace, or should i start doing it like u now straight ahead
  10. chrcun
    4
    Kingston,ont.Canada
    The Mechanic that is installing does this on a regular basis. I don't think thats my problem
  11. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    His way of installing the cooler may be why he is doing them on a regular basis.
    leftlanetruckin and Heavyd Thank this.
