2009 Freightliner Cascadia will not go into gear Help
Discussion in 'Freightliner Forum' started by caspers88, Mar 2, 2016.
  1. caspers88
    caspers88 Bobtail Member
    Hello everyone as stated above, my Cascadia is not going into gear the fault code i'm getting is 27 and the gear display is blinking NF,Also my Heater blower motor is not turning off even with the ignition turned off any help would be appreciated. My truck has a detroit 60 series motor and a eaton fuller smartshift 13 speed transmission.
  3. baha
    baha Road Train Member
    3,840
    2,414
    Jul 25, 2013
    ga
    Look at panel behind driver seat at ele. relays for water and green corr. when you unplug relays clean them up an ck. back for more info. ?
    caspers88 and rachi Thank this.
  4. caspers88
    Where is the panel behind the driver seat?
  5. caspers88
    Update on the situation transmission issue has been resolved but Heater Blower motor is still running even with the ignition off, Only way i can turn it off is i have to kill the master switch to turn it off
  6. baha
    3,840
    2,414
    Jul 25, 2013
    ga
    You can find fuse panel in most of them behind drivers seat inside plastic panel that runs up and down to rear of where door jam panel snaps in, you will find relays that can be wet from leaks above vents, seams from top roof panel can be calked up?
  7. RSQ20
    RSQ20 Medium Load Member
    The TCM requires good clean battery power, check the wires connectors and fuse holders..
    We have experienced this a couple of times, salt migrating into wire at terminal, turned the copper to mush..
    ... Philip
  8. Jerry12
    Jerry12 Heavy Load Member
    723
    280
    Sep 9, 2014
    What was the transmission issue
  • Draft saved Draft deleted
