I got a 2012 T700 with a Paccar MX 13, running cold all the time needing to Change the thermostat/s but I have looked everywhere and can not find any info for disassembly of the housing and everything involved in replacing. I was and still am mechanic but all I've ever dealt with is Cummins, cat, detroit, any info would help. Thank you
2010 Paccar MX 13 repair help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hoffa660, Feb 14, 2015.
Let me look for this up for you real quick. I have Paccar access.
Basically it's pretty simple. Drain the coolant (duh) and take off the thermostat housing just over the coolant filter. Had to look it up because I had a total and complete brain fart with the coolant module.
OK so when you remove the cover behind/above the water filter the thermostat is just inside there? I kinda thought that's all you had to do but I'm just not that sure about this new engine. All I know is dealers want 4 hours labor to do this at 170 an hr, I just can't do that just for thermostat replace. It looks like that cover is held down with about 5 bolts and after that it just lifts off?
jason6541 Thanks this. -
It looks like I need one also.
Thanks -
It sounds like I could do it myself.
