2011 D13 loss of power at 1,600 RPM
Discussion in 'Volvo Forum' started by JABA.logistics, Jul 10, 2020.
  1. JABA.logistics
    JABA.logistics Bobtail Member
    My 2011 Volvo D13 is losing power at 1,500 rpm about 70mph going uphill, downhill or on bumpy roads. The speedometer needle jumps back and forth between 60mph and 70mph. I recently replaced the housing primer pump and a gas line connected to the engine, since it wouldn’t crank up we thought this had fix problem, but the problem is still there.
    Trucking Jobs in 30 seconds
  3. kemosabi49
    5,923
    17,762
    Jan 13, 2013
    SW Arkansas
    Not enough info. If your tach is staying at 1500 while your speedometer is bouncing back and forth then there is something wrong with your speedometer.
  4. JABA.logistics
    The reason why the speedometer bounces back and forth is because it losses power. We thought it was the fuel water separator filter and got it replaced. while getting exchange at TA the truck didn’t start back up. We had to towed to a mechanic who found the house primer pump leaking along with a diesel line. We exchange both but the problem persist.
  5. QUALITYTRUCK
    1,466
    1,270
    Jun 14, 2009
    romulus,mi
    If you want to have success at T/A shop you must already know what problem is ex:flat tire,wiper blades bad,out of washer fluid etc. Get a proper diagnosis from a shop with knowledgeable techs.
    Socal Xpress Thanks this.
  6. daf105paccar
    6,256
    6,717
    Apr 15, 2012
    Have you looked up the powercurve off a D13?
  • Draft saved Draft deleted
